Cutlass Project
fraido2002
254
2
Mid Michigan
So here it is. I didn't want to start one of these threads until I was making some progress and finally I think i'm making some head way. Here it is the day I picked it up in Detroit, orginally a Missouri car.
Now I had it for a little bit before I started playing with it. If it didn't have a seized 307 I would've drove it around, but instead I went this route.
After I had the front end off I played around a little bit to see how bad the motor was. After I had water come out of 4 of the spark plug holes I figured it was toast. So out it came.
fraido2002
254
2
Mid Michigan
Then after a long time off of working on it, it's finally going off to a body guy. So off it goes.
There is a guy that is going to do the body work for my, he is a painter a dealership and gonna do it on the side at his house. He's also gonna swap out my floor pan and then reassemble it for me.
fraido2002
254
2
Mid Michigan
Well, I have a 403 out of a 77 delta 88. Its bored .30 over. I have some 7a heads built by mondello. They were on some guys 350 drag motor, he was going to a big block so he was selling his small block stuff. It had a comp cam in it when i got it so I don't know the specs. Put some roller tip rockers in it, I have an edelbrock 750 with a two inch spacer sitting on an edelbrock performer intake.
