Mission Objectives:
1. Use existing GM 350 Hencho En Mexico short block with no modificaitons
2. Use existing 600 CFM Edelbrock 1406 carb and Performer EGR Intake (currently plugged with included cap as I dont think my heads have the needed crossover?), flowtech headers, dual exhaust, no cat, MSD pro billet distributer (no multispark setup....yet)
3. Still use 87 octane gas
4. Idle smooth, not wake the neighborhood, be useful around town and get reasonable MPG of 12+ city, 17ish Highway (or better) (i have a TH350 transmission (tranmission, not cross dressor!) and 3:42 rear gears)
Preliminary research:
1. Edelbrock heads and CAM seem to be a good deal.
Question: Do I go with the 50 State Legal heads? Or the E-street series? Should I maintain EGR, i.e. will that help increase mileage and smooth idle?
2. I am sitting at 76cc heads and 8.5:1 compression. I am Thinking of using 70cc heads. That should be around 9:1 compression. I think...
Question: Can I still run 87 Octane? if so what do I have to look out for to avoid detonation?
3. Comp Cams has nice Ultra Gold rockers at stock ratios for much more reasonable price than Edelbrock, AND lifetime warranty.
Question: Will those mate up nice on the Edelbrock heads and increase horsepower? or should I stick with Stock rockers? Is 1.5 or 1.6 the correct stock ratio that the Edelbrock head require?
4. go with a matched Double Roller timing chain
Question, will that fit on my Hench En Mexico block without modification?
