Finally Doing A Build Thread
User avatar
350_85cutty
G Body Guru
Re: Finally Doing A Build Thread
Postby 350_85cutty on Mon Oct 19, 2009 6:32 pm
my buckets, they are in ok shape, but why not get them recovered while they are out the car...
I'm gonna get my pops to reupholster my bucket seats that I got from ebay and a non pillow top rear seat from my parts car and I was wondering where I could find these "buttons" i guess you call them that...my dad said to do w/o them and I might if i can't find any...any opinions on type of material? i was thinking close to oringinal material, cloth and vinyl sides in the tan/camel color...
another question that bugs me is my doors and the latches, don't know if they are something to really worry about just want you guys opinion....
just looks beat up, this is the pass door that i recentyl changed the door pins on
door works fine though
drivers side upper door hinge...again door works good
bottoms of passenger door what is the best way to go about go about fixing this? i cut out the worst part
'85 Cutlass Supreme Brougham: GM 350 Crate Swap (now 355 with mild cam), TCI Sizzler TH350, Dynamax Ceramic Coat Headers, True Dual Flo Pro Mufflers (catted), March Serpentine Pulley Kit, Powdercoated Olds Rally Wheels on Firehawk Indy 500s
78PontiacGP
n00b
Postby 78PontiacGP on Mon Oct 19, 2009 8:23 pm
wow i do have that same exact problem on the bottom of my passenger door make sure you replace youre weather stripping water might be getting inside and rotting it out
User avatar
350_85cutty
G Body Guru
Postby 350_85cutty on Mon Oct 19, 2009 9:28 pm
78PontiacGP wrote:wow i do have that same exact problem on the bottom of my passenger door make sure you replace youre weather stripping water might be getting inside and rotting it out
yeah my drivers side door is bad too, but I have yet to get the wire wheel on it, lots of scale tho...this one was bad, but I've seen worse on other ppls car...wierd cuz the rest of the car has no rust issues at all and the weather stripping didn't seem to bad so idk....and yes I will be replacing weatherstripping all the way around after it's painted..
also...that middle spot where the oval is, I know that's not rot, but what were the lil plastic inserts in those for? are those big drain holes? or some kind of door bumper when the door closed and rested on the rockers
User avatar
Blake442
Postby Blake442 on Tue Oct 20, 2009 3:34 am
I don't know if you'll be able to come across new square things for the seats, but you may be able to cut the old ones out and take them apart and reuse them. I'm not positive though... just an idea.
The wear on your door latches is a direct result of sagging hinge pins. When the door sags, the striker is no longer centered in the opening for the latch, and it catches the edge, making them hard to close.
Since you're replaced your hinge pins, you don't have to worry about it getting worse.
A lot of times you can pull out the latch mechanisim and straighten the lip of the opening with a hammer and dolly. I can't remember how much room them give you in there...
That oval shaped hole is a drain, albeit not a very good one...
Once that hot Texas sun dries out your beltline seals (window fuzzies), water easily gets into the door shell, settling right in that lower lip, rotting out the door from the inside, even down south.
Blake
'85 Oldsmobile 442--Olds 455/TH400/8.5"-3.73's/T-tops/non a/c
'83 Oldsmobile Cutlass Cruiser--Chevy 350/TH350/non a/c
'96 Chevy Caprice Classic--L99/2.93's/broken 4L60E
'62 Cadillac Miller-Meteor 3-way Hearse--The extreme baller shit
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
http://www.project-badass.com http://www.cardomain.com/id/Blake442
User avatar
350_85cutty
G Body Guru
Postby 350_85cutty on Sun Nov 22, 2009 9:26 pm
this is how I spent my friday night. after work I clocked out then got to work on my car
shaved my antenna hole, tacked in piece of metal, then filled, and grinded out the problem spot on my pillar where I had a stress crack showing thru the epoxy primer, I grinded it out and tried fiberglass filler this time around..after that I blocked my epoxy, had about a dozen low spots, but didn't glaze them was gonna see if the Polyester Primer would fill them. I spot primed the bare metal areas with epoxy then....
...shot 2 coats of the poly-prime...excuse the ghetto mask job, need to buy some plastic sheeting and masking paper
even got the header panel
guide coated then called it a night.
I have a question, the poly prime came with a liquid hardener, but most of it leaked out during shipping. I used what I had to do my 2 coats...I read there are MEK, and MEKP...MEK is a activator and MEKP is a hardener, like what you use with fiberglass...I bought 2 tubes of MEKP but have yet to use them was gonna see if anybody could shed some light and tell me something?
also. I took off the door weatherstripping, my dad mentioned that would be bad for my door hinges, is that correct? I'm tryin to get the outside bodywork done, then take the doors off so I can do the inner doors and jambs, and new weahterstripping installed after but I dont' want to mess up my hinges :|
User avatar
Blake442
Postby Blake442 on Tue Nov 24, 2009 6:05 pm
Lookin' good!
Not sure about your hardener question, but I wouldn't worry about the weatherstipping/hinge deal.
If you pull off your fenders, you can jamb your doors on the car with no problems, then you won't have to deal with re-aligning them again. Just make sure you clean really well around the hinges and stuff so the new paint doesn't start to come up after a while. I like to use those tooth brushes they give me for free at the dentist and Simple Green.
Might as well start looking for another hood too... is the one on your parts car any good, or is the car even still around?
Blake
User avatar
350_85cutty
G Body Guru
Postby 350_85cutty on Wed Nov 25, 2009 11:20 pm
got this side done
since the epoxy was thick and over some mostly sanded original paint, I blocked it wit 80, then 180, the scuffed it all with a red scothbrite...still have to rework the area around the quarter glass, and take off my upper door chrome reveal, so I just focused on priming below the bodyline
spot primed all my bare metal spots, with epoxy before I shot the poly prime...with the epoxy, it says to apply a mist coat, then come with a 2nd wet coat, I just ended up shooting the whole door and quarter on my 2nd coat, let flash then hit it with the poly prime...the poly was thick! I'm using the 1.8 tip on the gun, the biggest I have, and having to reduce it with acetone like it says, but still having a nice build
wax & grease remove, can't skip this step
the materials I was working with
safety first!
guide coated, now time to go home
nxt is the roof and trunk
the body is pretty damn straight, it was to begin with
User avatar
350_85cutty
G Body Guru
Postby 350_85cutty on Wed Nov 25, 2009 11:53 pm
Blake442 wrote:Lookin' good!
thanks Blake! finally got motivated to get things goin again...gonna try to shoot for getting it painted in time for the new year
this is the color I have my mind set on...I seen it in person on the same vehicle during the summertime, this lady that operated a snow cone stand in the area going towards my work had a Toyota Venza, never heard of it til I went to see what kinda of vehicle it was. I fell in love with that color
the pictures do no justice, couldn't find any pics of it in the sun, you gotta see it in person...i already got the quote for the paint...$346 that's base, clear, activator, and reducer...it's NASON, a DUPONT brand...I have a brand new SHARPE gun that I won back in High School that I've never used, was saving it just for this purpose to one day paint my car, so I'm pretty excited, haven't shot a base/clear before on a whole car, just single stage, and a test fender, but I'm sure I can handle it
yeah stupid me, I guess I don't remember reading the label on the back, i just pulled it out the box to use it the other day, it says MEKP hardener, so its the same stuff used with the fiberglass resin
good tip!
the parts car is still there, but the hood is way beyond repair, rust holes and MAJOR dents and hail damage
User avatar
Doober
Postby Doober on Thu Nov 26, 2009 12:36 am
I like the color! You don't see any brown really anymore. My dad's old Road Runner was a GM brown that was used on late '60s 'Vettes (from what he said).
-Darren-
'81 Malibu, Vortec'd 350, 4-speed Saginaw, 2.29s. Rusty.
'78 Malibu, de-framed, getting the drivetrain/suspension from the '81.
Looking to convert to a manual trans? Click here.
3XBrownCutty wrote:...ill check my nuts...
User avatar
Blake442
Postby Blake442 on Thu Nov 26, 2009 1:29 am
Toyota Venza? I've never heard of that either... I guess that's what I get for missing the Auto Show this year! :lol:
The Olds is lookin' good, and I think that color will look great on there. Keep up the good work! :wax:
Blake
User avatar
3XBrownCutty
Postby 3XBrownCutty on Thu Nov 26, 2009 10:00 am
Good color choice! lol, can't wait to see it on the car!
'83 Cutlass Supreme Brougham
Oldsmobile 355 TH350
Dynomax Headers, Summit 2.5" Dual Exhaust
800cfm Q-jet
7.5" posi 3:73 (soon)
Non-A/C
Rice Killer
http://s638.photobucket.com/albums/uu107/3xbrowncutty/
ImageImage FOR SALE: Edelbrock 1406, Saginaw 4-speed, 7.5" 3.23 Gears
User avatar
85 Cutlass Brougham
Postby 85 Cutlass Brougham on Thu Nov 26, 2009 1:37 pm
The Venza is basically the wagon...err crossover variant of the Camry, and equally dull and boring. You probably haven't seen one because it is so dull and boring as to be almost invisible.
1985 Cutlass Supreme Brougham (ex pizza delivery beater with 240,000 miles):
355 Chevy- 9.5:1 compression, Comp XE 262 cam, World S/R Torquer heads with 2.02's, Edelbrock Performer, 800CFM Q jet, Camaro ram air system,Edelbrock headers, Comp Magnum roller tip rockers,TH 200 4R, 3.23 rear, aluminum hood, IROC steering box, poly bushings, Eibach springs, etc. Cutlass build thread here: viewtopic.php?t=4982
Also: The Thing That Won't Die-1998 Nissan Frontier, 340,000 miles of pizza delivery.
User avatar
beermonkey9417
Postby beermonkey9417 on Thu Nov 26, 2009 6:18 pm
so about the scoop, wanna let me take it off yer hands? :lol:
Save Water, Drink Beer! Save A Tree, Eat A Beaver!
-'78 el camino, 307sbc, 14014416 heads, 1.6 roller tip rockers, holley 650 cfm carb, monte carlo interior, th350, rockford 4.11 posi PO-MutherF#$kin-S viewtopic.php?f=7&t=8386
-'94 saturn sl1, 1.9l tbi, 85hp, sony explod headunit, 1200w sony explod amp, 2.4 farad cap, no muffler, jvc 3-way 6 1/2" all around, kicker 12" twin voice coil sub, 15" x 8" chrome rims/ 15" x 6" stockers
-'07 47cc 2 stroke cag daytona, ported carb and #72 jet, stage 2 carbon fiber reed, race tuned exhaust, shwinn speedo, toyota badge, meat hook pegs, street fighter.
http://www.youtube.com/watch?v=efzbqvwBF9E
User avatar
350_85cutty
G Body Guru
Postby 350_85cutty on Sun Nov 29, 2009 11:16 pm
can I fix this or do I need a new upper hinge? anyone have one for sale?
also whats a good brand of weatherstripping to buy? Steele Rubber Products? for the doors, roofrails and felts, I priced it at $315 on the website, but I found this set on ebay
http://cgi.ebay.com/ebaymotors/1981-198 ... 0350807637
for $239 and it includes the trunk weatherstrip (which mine is still in good condition)
User avatar
username
Postby username on Thu Dec 03, 2009 8:36 pm
This isnt an expensive fix at all, I just rebuilt all 4 of my hinges for a grand total of like 25 bucks.You can get the replacement pins with a set of regular and a set of oversized bushings for 5 and change at autozone in there HELP section.The roller is a different story I ended up using one for a c/k pickup as I couldnt find one for a g-body allthough I didnt look very hard.Anyway the roller for pickups has the same dimensons save for being about 1-2" longer which I drilled the top of the hinge body the same dia.,cut off the excess and staked it,g2g.Now granted I have the doors removed which makes it nice because you can stick the hinge in a vise.
PreviousNext
Return to Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
