the carb I'm using is a Holley spead bore (4175) and the motor (305) is stock. I had issues with the carb on my older GP where the carb was running too lean. The carb's original jets were 61 and I'm up to 65 but in hot weather the car idles like garbage. The carb is the repalcement for a Quadrajet so it is supposed to be plug and play. Even though I have increased the jets I have the idle screws bottomed out which in this carb being a reverse idle richens the mixture in order to make the car idle without stalling. The car runs better in cooler temps in idle (almost smooth) and performance and I'm not talking a drastic temp change, just a few degrees and before you ask the engine is not overheating. I am running the original metal fuel line to the carb from the pump. I am starting to think that the fuel is boiling at idle and causing the lean condition. I was thinking of putting an eletric fuel pump in and moving the line from it's stock route and I don't mind going up another 2 jet sizes but I hate trial and error. I'm open to suggestions and hoping someone in here has had the same problem and the solution.
Thanks
Thanks
