CUTLASS Carb high idle stuck
Froggys86
231
55
California
Was wondering if someone knew as to why my 86 Cutlass Supreme would jump into a high rev while driving?...
So far it happened twice and the wife freaked our
MrSony
6,844
6,779
Des Moines, Iowa
bad choke coil, retracts while driving. that or linkage is sticking.
Clone TIE Pilot
3,881
2,647
Galaxy far far away
Could be a vacuum leak causing a lean surge.
Oct 14, 2008
8,833
7,796
Melville,Saskatchewan
I have also seen a rotted out hot air tube in the manifold cause this. The choke coil or gummed up linkage is more likely. Good carb cleaner then a lubricant works the best for sticking linkage.
