Exhaust Location Over Axle
tngbody
104
20
How centered does the pipe bend need to be in reference to the axle?
tngbody
104
20
tngbody
104
20
Also can anybody tell me the approximate location to put the exhaust hangers? The car had zero exhaust components when I bought it so I have no clue where to put the hangers.
403Olds
539
434
South Central Ohio
The factory hung them from the upper shock bolts. I put a hanger off the crossmember right behind the muffler, and one on the frame rail right where the tail pipe exits.
tngbody
104
20
Is it possible for you to get me some pics?
403Olds
539
434
South Central Ohio
Here's one that I found from when I was putting the exhaust on. You can see the bracket by the tip, then I added brackets at the muffler outlets. I'll make it out to the barn to get some pictures tomorrow evening if this isn't enough.
9,625
12,735
When I made my Monte's 4" tailpipes, I mounted then underneath the rear frame rail but they also bolt to the roll bar.
tngbody
104
20
