Pontiac- busted hand brake release
10,599
14,379
1983 Bonneville. I went to release the hand brake and the plastic on the dash [?] that it sits in- broke away. I was able to grab the body and pull the handle so I got the brake released. I was too busy, and pissed, to look at it. What is that part? The dash? Or the bezel? I have another bezel, but not a dash. Maybe a plastic or metal plate can be fastened in that spot. Any ideas?
9,291
15,762
I'd make a metal plate set up that would sandwich the spot. Was going to do something like that with the last dash in my Monte before it's too long redo.
10,599
14,379
I think that makes the most sense. But what is that spot on? The dash itself? I hope the dash doesn't have to come off to do that. I could not really see under there that low.
mikester
2,946
3,781
Small town NY
Look on page 16 of my wagon build. I had the same issue. The hole caved in when I tried to put the handle in.
I used a piece of grained plastic that I bought off of ebay. Carefully cut and filed the hole to shape and put it over the dash like a bezel. Marine epoxy and two button head screws. Not prefect but it works and with the piece painted to match the dash you can hardly notice the repair.
img_1561-jpg.85420
  • Creative
10,599
14,379
Maybe this might help,
Yes, that shows it perfectly. I also see all the divisions used the same part in the same spot, with minor variations of the dash shape. Good ol' GM one-size-fits-all mentality. Mikester that is a great repair job. Was the dash off or still in place? I think I have some very thin aluminum sheet leftover from a boat project.
mikester
2,946
3,781
Small town NY
To be honest I dont remember if I pulled the dash or not. It was a while ago. I do remember I had to use the epoxy on the bottom because the back had something in the way. Couldnt use small screws. Maybe a metal brace or something that was part of the dash frame. The more I think about it I think the dash might have been in the car but the seat was out so I could get up under there. I wish I had more info but like I said its been quite a while since I did it.
Needless to say I was pretty pissed that the hole collapsed just from pushing the handle in.
10,599
14,379
That's where I am right now. I have a power seat base so removing it is a chore. All I can do is move it as far back as possible. I stuck my head up under there as far as I could but I can't see much without removing things. I am going to have to move one project out of the way so I can have room to work. This just one more instance where having too many vehicles bites you. But thanks to you guys I see what needs to be done. Thanks!!!!
mikester
2,946
3,781
Small town NY
Remember, if working on cars like this was easy everyone would own one. LOL
10,599
14,379
I had to wait until I dragged the Whaler home for winterizing. Now I have room and time to work and the weather was great today. I cut a sheet of aluminum plate to fit that spot, then ground out the hole where the release sits. A combination of sheet metal screws and epoxy secured the aluminum plate to the spot on the dash where it broke off. The release handle pulls out OK, now to wait for it all to harden up. A bit crude, but the knee bolster will hide the ugliness. I can't believe how I still apply the brake out of sheer habit, even knowing the darn thing was busted!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMG_0727.JPG
