Has anyone installed an H pipe on their G body? I need pics
bawazir
405
4
Has anyone installed an H pipe on their G body? please post pictures if you guys have one
Do they sell a kit for a G body el camino ?
Thanks guys
Veltboy618
549
Re: Has anyone installed an H pipe on their G body? I need p
bought this for $100 with Flowmaster 40 series
A couple pics of my g-body
cross member before
cross member after
Had to cut it so it could go over the rear end
tacked them back on & hung it up
hooked it up
hangs kind of low but ifs fine with me
86_olds
579
so cal
not bad veltboy good thing our cars still have lots of ground clearence
stomis
403
Brick NJ
Theres loads of room under a g body. The summit brand generic X pipe setup should work great. If your waiting for a review just gimme a month or two and I'll shoot some pics of it when I get mine done.
jrm81bu
3,000
48
Antwerp, OH
I ran an x-pipe instead of the h-pipe, here's some pics. It's a Pypes x-pipe system and homemade crossmember.
Mike P
446
208
Arizona
I went with a Pypes X pipe too along with turbo mufflers and Flowmaster tail pipes modified to exit behind the tire on my 83 El Camino.
Veltboy618
549
Homemade crossmsmber looks good. I think it would have looked cleaner if your mufflers were flat instead of at an angle
jrm81bu
3,000
48
Antwerp, OH
I was still fitting at that point(although it still sits like that). I was having some issues with making the tails clear with how low the car sits. The slight angle of the mufflers helped with that.
tc1959
3,963
1,975
Surprise AZ.
tc1959 said:
I had mine run down the rt side.In to a dual inlet,duel outlet cat converter then split in to duels with super 50's FM mufflers.
I have a link to youtube so you can hear how it sounds.
You don't need to modify the cross member, because the 2 in 2 out cat acts like a intermix chamber much less work and expense then a x pipe or the old h pipe. It still performed and sounds very nice,check it out
8)
