Plastic Horn Disc Thingy In Steering Column With Grant Steering Wheel
Supercharged111
4,955
7,758
Colorado Springs, CO
Mine was broken, so I swiped one out of a 4th gen Camaro parts car that won't need a horn but it looks to be a bit too tall for my Grant steering wheel adapter setup.
This should sit flush. Does the Camaro piece look taller than the Monte piece or should I have had some sort of spacer behind the adapter? And yes, I need to remove that adapter to slip the plastic cover dealio over the lock plate. Doh! Good news is that the horn relay clicks when you touch the wire to ground. And I have some pretty loud aftermarket horns for this that have been on the shelf forever collecting dust.
