Quadrajet or Aftermarket?
12,180
9,808
I have the old TES headers on my SBC. Only issues I had is to run spark plug heat sleeves and tight sparkplug access on some cylinders. They used to sell special telescoping sparkplug sockets for headers, which I have one of.
My original set of Accel 8.8 wires had large boots on them and were slightly thicker wires. a few of them became casualties of the headers. I changed over to Taylor 8mm wires and they seem to clear the headers without any issues. Well, the wire looms help significantly as well..
12,180
9,808
In some cases you need a few different types of sockets. The spark plug socket with the hex is useful and a 5/8" combination wrench helps as well. I also use a swivel socket if need be.
10,590
14,355
Jack, since you had VW beetles, you know that the ONLY way you are getting the spark plugs out is with a flex-head ratchet. I think it was invented just to service Bugs!!!
12,180
9,808
Mark,
I've never used a flex head ratchet for that purpose.
I'm quite familiar with air cooled VW and 4-cyl. Porsche engines. What I generally use on the Porsche engine is a magnetic 13/16" socket with a basic 3/8's drive ratchet and extension. The Porsche engine has a deeper reach to access the plugs and therefore it's easy to lose a plug inside the shrouding. Ask me how I know. The magnetic socket is a godsend. It's a German Hazet brand. Worth every penny .
Before using the magnetic socket, I used a regular spark plug socket to loosen up the plug and then use a length of fuel hose to fit over the plug's porcelain . It works almost as well as the magnetic socket. We all have our various methods.
It does take a little care to not cross thread the SP threads, and recommend using the finger tight method before tightening down the plug.
Clone TIE Pilot
3,879
2,641
Galaxy far far away
I use stock AC Delco wires with Ebay fiberglass boots, one of the few times I use cheap Ebay stuff.
12,180
9,808
Are they a silicone jacketed wire? Also what type of core wire does it use? I like to use a silicone wire with a spiral wound core. which is why I like the Taylor wires. Even brands like Moroso, Accel, MSD, etc. are made in that fashion.
Clone TIE Pilot
3,879
2,641
Galaxy far far away
I just use stock carbon core wires. Many of the spiral core wires have poor suppression.
10,590
14,355
Jack I had a cheap-azz guy at work with a VW Bug. He wanted to do the spark plugs but could not get near them with the tools he had. I suggested a flex head ratchet and he just poo-pooed me as being a stupid know-it-all. So I did NOT offer my tool for him to use. This went on for couple of weeks with no success. Finally he admitted that he had used a flex head ratchet to get the plugs done. It cost him a lot because he could only find one for top dollar at an expensive hardware store. Oh... well............. :mrgreen:
12,180
9,808
I guess this schmoo learned a lesson. Like the old adage goes, you can lead a horse to water.
8,832
7,791
You chebby guys are funny with your burnt spark plug wires. The only time I had issues was my hot running 403 with MSD Superconductor wires, heat actually cracked the wire twice, no actual touching on Olds V8's. Once I put on Accel 25 ohm race wires and years later the GN rad surround on my G body, problem solved.
