Anyone have a junk frame? I need a piece from a bad chassis.
87 GN
232
35
Philly Area
I need the last 10-12 inchs of a damaged or junk frame for the passengers side to rob the body mount perch off of.
See pic below. I currently do not have a perch on the right frame rail as a wagon should I need to add the perch on the right frame rail. It looks the same as the perch on the left. Trying to save from fabbing something up. Thanks
Clutch_Grabwell
218
9
Millbury, Mass.
Re: Anyone have a junk frame? I need a piece from a bad chas
Edit: Just noticed this is the wagon forum.
Got no clue what the end of a wagon frame looks like... :wink:
87 GN
232
35
Philly Area
On a wagon it should be there. The car rode fine on this chassis before and would again without it but I want to do it right so I need to add it.
87 GN
232
35
Philly Area
The picture below shows 3 different sets of GM body frames for the 1978 - 88 G body's. The frame on the left is for the El-Camino, the middle one is the car, and the one on the right is the station wagon.
87 GN
232
35
Philly Area
Sorry guys but I didnt start the thread for this debate I know what I need, been working on it now for 3 years. The wagon body is on a sedan frame from a GN. The sedan rear body mount locations are different If anyone can help me find the piece I need let me know otherwise Ill fab something up. Thanks
pontiacgp
blank
Mar 31, 2006
29,270
20,417
Kitchener, Ontario
here is the picture of your frame from your thread and I wasn't trying to debate you...like I was trying to tell you ,there is no bushing perch there
87 GN
232
35
Philly Area
Thats the same frame that was under the car when I took it apart. It didnt have the perch cause its a gn frame so it was missing the rear bushing on that side. To add it As a wagon should have I need the perch.
The last bushing on the frame in the pic you posted was just sitting in there. There
Is no bolt in the body to tighten it. So if I add the perch as the frame should have I can locate the bushing to the proper location on the body and it should help stiffen the car up
a bit.
pontiacgp
blank
Mar 31, 2006
29,270
20,417
Kitchener, Ontario
I didn't know a GN frame would fit under a wagon...
